Results 1 to 15 of 15
Thread: Flywheel help 2.4
    New Orleans,LA
    1991 Mitsubishi Mighty Max
    Flywheel help 2.4
    I've got a 91 4g64 (6 bolt) but can't find a stock flywheel anywhere and I'm not buying the $350 findiza one anyone have a part number for one?
    redding ca
    New Orleans,LA
    Thanks a million, I used to see these trucks everywhere a few years ago now I'm the only one in my area. Not a one to be found in a junkyard either.
    Haverstraw NY
    1986 Dodge D-50
    G64B
    while on the flywheel topic does anyone have a chart with flywheel weights over the years? and dsm ..
    looking for the heaviest i can install on my g63b 2.0
    I'll wager the original G63B SOHC flywheel will be the heaviest anyway. AFAIK there isn't a weight chart for them - interesting info to chase for a thread...
    miami, fl
    1991 Dodge D-50
    Later starion 2.6 flywheel is a 35+ pound slug
    2.6 would have a bigger flywheel than the 2.0 due to the wide/narrow block thing anyway. I want to fork out for a lightened stage 2 flywheel for Hung Dog wagon now I've upgraded the brakes (went from non-functioning rear drum to disc lol)
    Just take the one you have to a machine shop and have them turn it down by 5 pounds.
    By using a lighter one it will rev faster but it's harder on the clutch springs.
    Quote Originally Posted by Goopy performance View Post
    So yeah he wants the full mass flywheel.
    miami, fl
    1991 Dodge D-50
    probably responding to your post.
    https://www.racetep.com/engine-build...ightening.html
    used to do most our starion flywheel lightening back in the day ~$120. Shaved a whopping 21-22 pounds ! No failures
    miami, fl
    1991 Dodge D-50
    that is shed a whopping 13-14 pounds. I got the later one with the bigger 240mm clutch
    We're going off topic now but the kit I'm thinking about has a carbon/kevlar composite 6 spring clutch plate + HD pressure plate and a prolite 9.82 lbs flywheel. The kit itself is only $150ish USD (add an extra $100 to ship it to me...grrr) I couldn't get a flywheel machined down and have a full clutch kit thrown in at that price locally. *this is for a Hyundai G4GC type 2.0 twin cam so it's not relevant to the site but here's an ebay link anyway
    1993 Mitsubishi Mighty Max
    Later Starion 2.6 flywheel is a 35+ pound slug
    The Starion 2.6 flywheel 35lbs..??
    I also drive a '95 Ford Probe GT with a Mazda 2.5 V6 that comes with a 17lb flywheel.
    And I swapped that out for a 13lb flywheel from a Mazda MX-3 2.0 V6.
    miami, fl
    1991 Dodge D-50
    yeah.... the racetep link posted even mentions it. Might be closer to 36# iirc
    Mitsubishi Starion 2.6 Turbo...35 lbs. stock / 21 lbs. lightenend
    ebay kits are a helluva bargain. Even many of the inexpensive starion XTD clutch sets hold up on 300-350 ft-lb moded street 2.6
    Oddly, never seen a 2.6 lighter performance flywheel offered with the 2.6 clutch sets. I'd think it would be a welcomed/popular addition
    Haverstraw NY
    1986 Dodge D-50
    G64B
    thanks guys for the helpp...the narrow block flywheel is what i am after..will post pics of my cherry 86 soon..you guys will love it..
