Results 1 to 4 of 4
Thread: weber carb adapters
    Wasilla, AK
    weber carb adapters
    Does anyone make a one piece carb adapter for the ram 50 to weber.
    Thanks,
    Cant Say
    Dodge V6
    If your intake manifold has that odd dogleg spur off the carb mounting face (for EGR? And I think only some years of 1st Gen had it?), the 2-piece sandwich kit from Redline (US) is the only one I know of with provision for that.
    Otherwise, I've found a couple alternatives that seem like they have the same bolt pattern as our stock Mikuni:
    Trans-Dapt 2107 - Note what may appear to be two pieces are actually a single cast piece with flanges connected by a riser pipe, which I gather should theoretically improve torque somewhat. Pretty sure I've seen pics on this forum of at least one Weber swap using this adapter.
    Redline 99004.300 - The only low-profile alternative I'd seen (before Geez linked that nice Aussie one here), but note the cast-in ramp under one barrel making a sharp transition to adapt the barrel spacing, which seems likely to impair performance somewhat, but I reckon could also improve emissions with greater turbulence helping blend the air-fuel mix. I'm also not entirely sure the cast-in barrels at the manifold face would be well-sized and -spaced for our manifold, since we're an off-list application for this adapter.
