Results 1 to 9 of 9
Thread: Lowering kits
    Anderson sc
    1986 Dodge Ram 50
    4G63
    Lowering kits
    Does any manufacturer make 2" dropped springs for the first gen ram 50?
    Columbus, OH
    aim industries makes drop coils also. Be sure to cut the front bump stops in half so the is room for the suspension to travel.
    Lynnwood, Washington
    What about the rear? What is the best suggestion on getting that back end down?
    Blocks. And cut the bump stops down to almost nothing
    Josh
    09 BMW 335i E92 Twin turbo
    Rearch the rear springs and have the eyes reversed - reversing the eyes will give a 2" drop by itself, and rearching eliminates the axle on stilts issues that blocks creates. This requires the springs to be modified by a spring shop. Realize too that our leaf springs are 2 3/4" wide, not 2 1/2" or 3" and not normally found at a spring shop. Another reason lowering blocks are bad if you want the suspension to work well as they are all for 2 1/2" springs and allows the blocks to shift due to the gap between the u bolts and the blocks.
    British Columbia, Canada
    1986 Dodge D-50
    FWIW, here are the part numbers for what I put on my '86. Belltech stuff. Perfect fit.
    Part # 4270 Belltech coil spring set, 83-97 Mighty Max, 2.5" front drop
    Part # 6200 Belltech lowering block kit, universal 3" block, blocks, u-bolts, hardware
    Part # 8000, 8517 Belltech shock absorber, Nitro Drop 2 (front, rear)
    -RHP
    Stafford VA
    1987 Dodge D-50
    sorry to bump such an old thread, but the mighty max springs will fit a ram 50? Im just looking for verification because i do not want to order them and have to send them back.
    same trucks - Dodge bought them from Mitsubishi and rebadged them.
