Originally Posted by
Chargerx3
I think you are referring to me and my Mad Max build.
Correct the hardest part is the electrical and getting a good base tune.
Any 6G7* motor will bolt up to your transmission. That is the great part. Bell housings are all the same for that family of engine. If you want to not have to worry about more wiring work, or another ECU integration you will need to go one of two paths.
1) Get an identical 3.0L out of another car/truck that is SOHC, and has a dizzy.
2) Get a 3.0, or 3.5 with dizzy, or go dizzy. Will need to swap out some parts.
3000gt will work, but get the base model with SOHC and dizzy not the DOHC and coils. It wont work as a plug and play.
YOu cannot use a 3000gt trans or any other trans for that matter with your 4x4 truck. If you were a 2wd truck then there is a rare kia trans that you could put in for RWD only. Your Trans is a V5MT1-1 and is very strong. They are pretty much bulletproof for anything you will throw at them. Im at 300hp and no issues.
Yes as mentioned above.
It will work. Just keep all your parts off the truck engine like the exhaust manifolds, intake manifold, dizzy, fuel rail, coolant manifolds, and fan. They will all bolt up. Only issue you will run into is weather or not a car 3.0 has all the proper lower block bosses to accept your truck motor mounts. They usually do, but if they dont (like my eclipse motor), you can make them work with bigger brackets, or welding.
Yup thats it. I should update my pics huh?
