Results 1 to 2 of 2
Thread: Help! Is my output shaft bent?
    Cant Say
    Dodge V6
    So I noticed that when i pulled my engine my output shaft was pointed down relative to the bell housing. Is it supposed to be that way? If not I will replace the bearing with a bushing. I noticed it on both the 82 and 87 but they both had different transmissions.
    if you grab the shaft and it has play - the input shaft bearing is shot. easy fix.
