Results 1 to 10 of 10
Thread: Hub Flange Diameter
    Hub Flange Diameter
    Can someone please explain to me why everyone tells guys they need to bore Nissan/Chevy wheels out to 108mm in order to fit on our hubs? This is not meant to be contradictory or confrontational at all. I just do not understand where the 108mm's is coming from. []
    Cant Say
    Dodge V6
    idk, i kind of want an answer too lol.
    As shown in the above photo, the size of the hub mounting flange is actually 93mm. The bore on stock wheels is 93.6mm. if you were to bore a Chevy or Nissan wheel,93.5mm would be ideal. They would center perfectly on the hub and hub rings wouldn't be required.
    88 up GM truck 6 bolts are 88 mm bore, so that is not a bad amount to bore out. May need bulged lugnets depending on year of GM wheel used - 12 vs 14 mm
    Nevada
    1991 Dodge Power Ram 50
    4x4 hubs are larger than rwd trucks. You need 108 to clear the front hubs.
    Cant Say
    Dodge V6
    oh that makes sense
    Do 4x4 trucks utilize different rear axles and brakes?
    Cant Say
    Dodge V6
    yeah the rear on the 4x4 is 8" 7.5 on the 2wd. the 4x4 does have drums, like 12 or 13" drums
    Nevada
    Yes 4x4 is larger on both the front and rears.
    Ca
    1993 Dodge Ram 50
    Thanks again SA22C.
    For context Honored Posters Who's info is accurate ???
