I'm having a really hard time finding this pulley. I've ordered one thinking it was the correct one since it was advertised as the Accessory pulley, but was still incorrect. Can someone point me in the right direction.
Is it a ribbed or V belt? I found this listing for a ribbed belt - https://www.ebay.com.au/itm/Dayco-Id...0AAOSwoaNdo2KP
Need to do some part# cross referencing...
Well, here goes attempt #2 - https://www.ebay.com/itm/NULINE-A-C-...a43d%7Ciid%3A1
It has the pulley dimensions on it so it might be a match -
Don't forget they sold Mighty Max under different names so remember to not limit your searches.
Yea. I remember, thanks for your help but unfortunately that's not it either. Looks almost exactly like this. But this one says it's for a v6
1990-1994 Mitsubishi Mighty Max Drive Belt Tensioner Pulley - API 2008-481903 - Alternator - PartsGeek.com
https://www.partsgeek.com/bd6hrbm-mi...er-pulley.html
Try Dayco # 7093-05032708 or Dorman #W0133-1859045 .
Also if memory serves the bearing can be replaced alone,
price range from $2- $10.
I've done a bearing swap on an idler. Cheaper and easier than trying to get a replacement pulley. Claych nailed it by suggesting the obvious - we should've asked if you were only replacing the pulley due to a dead bearing
