Results 1 to 10 of 10
Thread: Custom fender flares???
    Cant Say
    Dodge V6
    ok so i have a 87 dodge d50 and i was wondering, has anyone went widebody or flared fenders??? i have a fair bit of offset and it looks good but i was looking into flare to accomodate even wider tires. they are currently 9 and a quarter wide (235). thanks! wheel_offset.jpg
    I think someone has used Montero/Raider flares. Obviously not a straight bolt on but Maxs' never had them as an option. I believe they are NLA as a new part but there are repros floating around (they are not cheap...)
    Smithsburg, MD
    I have a set of these: https://www.ebay.com/itm/Fender-flar...0AAOSwR0JUS~L-
    I'm not going to use if you are interested in buying them. I trial fitted one (just drilled out the mounting holes) and the other three are untouched Comes with everything like in the ebay ad. PM me if you are interested and I'll snap some pictures of them this weekend.
    Cant Say
    Dodge V6
    Quote Originally Posted by steve1814 View Post
    How much does that add? I was looking at 12" tires last night, i can fit those no problem. I want about an inch of offset from the flare.
    Cant Say
    Dodge V6
    btw i like those rims. 15"?
    Smithsburg, MD
    That is a pic from the original seller, I have no idea what size the rims are-sorry. The flares stick out about 1.5 inches from the body line at the top and increase to about 2.5 at the bottom rear
    Cant Say
    Dodge V6
    hmm i will look into those
    Smithsburg, MD
    if you are interested, I can sell you mine for a good price.
    Cant Say
    Dodge V6
    i think ill pass, i found a set of custom metal flares.
    Frederick, MD
    The 2nd gen 4x4 Mighty Max's did have factory fender flares, but (I think) only the higher trim levels came with them.
