In another thread I had the idea of making a mold to make new silicone transmission boots for our aging transmissions, but the more I did the math I realized it probably isn't feasible to do so. Geezer mentioned the idea of finding a similar boot that would work instead. So far I have come up with the following as a possible replacement for the MD703619 boot. This is the standard 5 speed shifter boot used up until at least 95'. I have not tried it myself and as of the time of this posting and there are OE ones available but I wanted to share my results in case these become unavailable in the future. If the link expires the boot is for an Allis Chalmers 6060, 6070, and 6080.
I will continue my search to find a replacement for the 4X4 shifter boot, part number MD704149, since it appears that I have the last NOS one around
If anyone finds any boots for any of the other transmissions ( I think the 4 speeds may be different?) please post them here! after all no one wants dirt, sand, or water in their transmission or transfer case.
This setup is off a Toyota truck I picked it up at a towing place where I picked up a parts truck from, it looks like it would work just trim off what you don’t need. A guy could separate the 2 boots and change the angles if needed and cover the repairs with carpet or sheet metal maybe. If not center the shifter so it works with ease then make the transfer case shifter work when needed.
Pretty sure the intact ones are molded to the shifter on the bottom to protect the shifter from getting dirty from under the body it’s a PITA to get the bolts out but it’s doable. With the amount of smaller stick shift trucks out there boots should be around think Toyota, Mazda, Nissan and the other Mitsubishi trucks that use the same trans/transfer case equipment.
I needed to change out a shifter a few days ago on the truck that was in the fire the shifter was locked up from the pivot ball melting. I used a second shifter I had that had a full boot to move the truck when I could shift into neutral it sucked fighting that boot.
Get a firm grip on the edge of the boot peel it up towards the shifter to reveal the shifter plate bolts the boot will fight you every step of the way. I use a 1/4 inch extension and ratchet because it’s a tight area to work with.
The boot I have is all one piece still the floor boot cover covers everything from the shifter shaft to that boot on the bottom. Most boots are ripped or separated over the years by wear and tear or to make working on removing the shifter easier. I did need to change a cracked bolt down plate on mine years back and the guy used a press to separate the shifter in that area not sure if that’s needed on yours just saying what I needed to do in my case.
I did see a thread on here somewhere about someone changing their worn bushing on the transfer case shifter. Of course, when I'm looking for it I can't find it. I assume whatever process they employed to do that would be the same for changing the boot.
BTW, those boots are available stateside from lusooverland in AZ. I also got the hood prop clips from there.
