Hi, just stumbled on this post, could be a lifesaver for me but I got a quick question and I hope someone still here to give advice... When swaping to the DG27 did you retain the original coil with the ballast resistor or did you replace it ? When I crosscheck which car compatible with the DG27 dizzy it looks like those were equipped withe the cylinder style coil. Many thanks,
