Results 1 to 13 of 13
Thread: Wobble Wobble HELP/ Hub Assembly
    There is no way a hub would be made with the studs off-drilled. The hub itself must be buckled (would take a hell of a hit laterally to do it but not impossible). Or maybe the mount isn't seated properly. Take it apart and do a visual inspection of everything - but I'd cut to the chase and just get another one from a yard rather than play around with it.
    I wouldnt think one could be produced out of round myself... Thats why Im scratching my head and going crazy. Ive replaced some really bad wheel bearings that make noise like crazy and do the typical bad wheel bearing stuff. I just wanted to see if there was some oddity in design that I might be overlooking.
    There are 4 in the local u-pull-it. An 86 that Im dying to check out, and 3 early 90's. Cross checking part #'s shows they are all the same hub/bearings. So.... hopefully Ill find a couple that will work.
    Thanks for the input Geezer.
