Junior
I figured. Just wasn't 100% if they are interchangeable. I'm trying to find one with a water pump included, as it is usually cheaper, but may just have to order the kit and pump separately. Getting more and more eager to toss some boost at it the more I browse through parts, but I'm trying to replace everything that is a basic normal wear part while I reassemble.
Been a while since I've had a street truck. I pretty much melted the 383 years ago bouncing off the limiter for 30 solid minutes, as the younger version of me was far less wiser.
