Results 1 to 7 of 7
Thread: New 2.4 oil pump, Notchy??
    Spartanburg sc
    1993 Mitsubishi Mighty Max
    Putting a fresh head on my 4g64 and new oil pump etc. was about to instal timing belt and the oil pump gear won’t “fall over” so I can time the oil pump/balance shaft It seems notchy, and makes it worse when I forgive the silent shaft above the oil pump.
    Am I missing something or it is because the pump is dry? I even tried pouring oil in the pump
    As I recall, the shaft will only spin in one direction. The most tension is between the cam cog and the oil pump cog. Not sure what to recommend, and I hope someone comes along and can give better advice.
    What else have you done while installing the oil pump? The pump gears should allow the pump sprocket to spin both ways. If you wanna get to know the ins and outs of 4G6X engines, watch Jafromobiles' channel on youtube. He is thorough and explains the whats and whys. He has a stellar video on 6 and 7 bolt oil pumps and also the process of balance shaft deletes -
    https://www.youtube.com/watch?v=DPhyazI1fYc
    Spartanburg sc
    Here’s the back story, bought a 145k mile truck for parts, kept motor for my 4x4 Ram 50. Had a blown head gasket, had fresh head done, wanted to replace oil pump and all seals etc. I was very concerned about aftermarket oil pumps since I couldn’t get a melling or Mitsubishi and here I am lol... I bought a enginetech off rock auto. Pump didn’t feel smooth before I put it on, thought it was because it was dry. Well got it all bolted up and even put some oil in it and it’s hard to turn or notchy almost like a bent Silent shaft? I was trying to set the timing in oil pump gear with timing belt when I realized it. It not smooth at all and won’t fall to either side so I can time it correctly. Needed up removing everything and sticking the old pump back on the engine and it’s 85% better I guess I got a bad pump? My luck.
    Spartanburg sc
    Here is pictures of my silent shaft and bearing. It turns smoothly without the pump just thought I’d ad this in
    I think that was a wise move. Let's say hypothetically you installed this pump and straight up started the engine and the pump shredded metal for some reason - it would've potentially killed your engine in minutes. Hope you can get in touch with the supplier and get this sorted out.
    Spartanburg sc
    Hope so, I was concerned about the shaft and bearings until I tried the oil pump. Anyone have any recommendations on pumps? I see bad reviews with dnj so I went with rock auto. Not sure what to do now on a pump
