most twincharge final result suck or fail, because the 'builder' went too deep over their head
Make sure u capble of simply a perfect running turbo setup b 4 even attempting twincharge
Not only is the plumbing nightmare, but the heat management and most of all the transition between super-to-turbo
1.6 MR2 "drove like a turbocharged hi compression strong V6". Superb torque off idle to 7000rpm+. Ran mid 11sec 1/4, ~20years ago
