Results 1 to 12 of 12
Thread: Temperature Switch for Electric Fan Install
    Menifee, CA
    pharmorjawn,
    -A/C lines below the distributor in Your first pic?
    -Sport dash with tach?
    TIA.
    Yes those are A/C lines and it is a sport model. You want need a cluster with a tach?
    miami, fl
    1991 Dodge D-50
    clutch fans work very well. What's the problem ?
    You're gonna b adding relay/fuse/wiring anyway with an electric fan.... so what's a sensor wire ?
    once u find the appropriate spot somewhere along the cooling route, u can screw in some oem or aftermarket fan sensor with a pre-set temperature
    I've used this simple type of adj sensor before http://www.amazon.com/dp/B01E52O5DG ~$15 back then
    probe was either radiator fin type or clamped into top radiator hose. Worked well
    Hayden also used to make an adj sensor/relay kit for dual fans.
    Main fan came on 1st, 2nd fan at higher temp or with AC compressor. Worked excellent. $30. Don't c em anymore tho
    Menifee, CA
    Fan clutch was broken and electric fan i got was only $10 more than a replacement clutch.
    Also, i just wanted to something to my truck
    Ca
    1993 Dodge Ram 50
    Quote Originally Posted by PharmorJawn
    ???? 10 posts ????
    Menifee, CA
    ???? 10 posts ????
    ???? 230 posts ????
    not sure where this is going lol
    Menifee, CA
    Just to close this out....
    i was able to replace the sensor in the first pic with a temp switch since my ac switch is broken and i had to bypass it a while ago. Electric fan works great after upgrading my alternator to one out of a Mitsubishi van.
