Transmissions leaking fluid between engine and trans. Help?
Hi guys! Looking at picking up a 91 Dodge Ram 50 with the 6G72 and the auto transmission. I have experience with Montero's and this motor and it runs strong. The transmission is leaking lots of fluid where the engine meets the trans. I shifted it from Park into Drive and a ton of fluid came out. I have done some looking around, but cant seem to find any info on whether it could just be the front seal leaking or if there is another problem.
Any advice would be greatly appreciated!
