Okay that means the small line connection is the supply, I just need to look at the bottom of the filter block for a connection. Thanks skullzaflare, I assume you put the 4D56 alternator on yours? All my Stuff is Mitsubishi so no worries there, did you just run the factory wiring when you did the swap?
Thanks again
