Results 1 to 3 of 3
Thread: Coil Swap
    Bothwell,Ontario
    Coil Swap
    Since my truck has been having terrible mileage and a lack of power I thought I would see if it was a spark issue.
    I swapped the stock coil for a PS 91 Crane coil I had in my 65 Chrysler.
    Surprised to find I have more power and the truck actually pulls not bad (for what it is) to 4000 and I don't use as much throttle ( running at 50 mph at 10 in of vacuum instead of the normal 6 in).
    I'm assuming the stock coil just wasn't putting out enough voltage or something... but the truck seems happier.
    On Tuesday I pickup the exhaust gasket so I can swap the cracked exhaust manifold for the one I have off of a 88 ram with a 2.0. I just have to weld up the EGR tube.
    Next up is the head swap from the 2.0.
    Siskiyou County, CA
    The factory coil on my truck gave me all kinds of trouble and i didn't realize it was the problem until i replaced it with a new Bosch factory fit replacement. it made a huge difference in drive-ability.
    Bothwell,Ontario
    I find the truck idles better... a little bit better mileage. Most just drives way better
