Results 1 to 2 of 2
Thread: Mechanical Fuel Pump
    Lexington, NC
    For some reason the fuel pump has zero suction and its new and everything with the cam is moving it like it should, is there something I can try to do?
    Siskiyou County, CA
    New pumps can be duds right out of the box. do you have the little spacer installed between it and the head? if possible can you see if it will draw fuel out of a small gas tank with a piece of hose? this may tell you if the pump is working or the filter is clogged.
