We checked the ECU and while the capacitors do not outright look bad we did find something else.
My dad is going to take my ECU to his job. He plans to sonic clean the board, replace all the caps and repair the pins/traces that were damaged by the corrosion. Afterward he said he will coat the back of the board with lacquer to seal it. Hopefully this will be the fix I have been looking for.
