Get a wire wheel on a drill and give that metal ledge sticking out of the block next to exhaust port #4 (the top face which would be the block deck) a pass or 2. The engine number and block designation code should be stamped on it. Your truck has had both an engine and transmission swap going by the numbers on that ID plate.
I’ll give a good brushing when I get home from work today. This engine and transmission definitely has been swapped. They came from a d50. The guy that swapped them has no idea of year though. They were swapped out about 15 years ago and the truck has been sitting for about 13 yrs now. All he could tell me is the d50 looked identical to the mighty max.
