Results 1 to 7 of 7
Thread: Dodge ram 50 2.6 barley can hold 70 on interstate
    portland tn
    1988 Dodge Power Ram 50
    Is there any power mods for a 2.6 motor
    There are the usual go-to's of a bigger carb (the old bench mark was the Weber 32/36 but the newer 38 DGES has got an edge over it), good headers and exhaust system, a good street cam, some port work and deleting/disabling the EGR system on it. Experimenting with the ignition tune will yield hidden torque and throttle response. Beyond that you'd need to think forced induction like the engine and ECU from a Conquest.
    Check the performance section of the forum for tips and how to's as everything has been covered extensively
    Earth, the Solar System
    I have the 85 2.0. It does 80. It will do 70 with a half yard of wet gravel in it. It takes a run up but it will do it. Check all the moving/rolling parts for proper lubrication and that they aren't worn out.
    Tucson, AZ USA
    70 MPH should be no problem for a stock 2.6 in good running order, so check the usual basic tune-up stuff -- esp. make sure your static ignition advance, centrifugal and vacuum advance are all within spec. and functioning correctly.
    *might be worth your while doing a general ignition/carb check as well. A crappy coil will lose spark under load - it ends up with poor MPG and engine performance (average working life of a coil is about 10-15 years max). Make sure the tune is reasonably good (plugs and gaps, serviceable ign parts etc) If you are pretty sure the carb has never been apart, it is due for a tear down and rebuild (this will be the time to think about a new carb to save yourself the grief of trying to put a kit through the stock carb, this is not something you'd want to tackle as a noob)
    Seattle, WA
    70 MPH should be no problem for a stock 2.6 in good running order, so check the usual basic tune-up stuff.
    I agree completely. Have you tested the engine’s compression? Acceleration and top speed will suffer if one or more cylinders has low compression.
    Lawsonville, NC
    4D55-T
    I’d also check the exhaust it it’s still stock exhaust. I’ve had the cat stop up and also the muffler it self. Only way I found out was I finally had enough and thought about that and cut the exhaust before the cat and took it up the road and man what a difference it made.
