Results 1 to 25 of 184
Thread: 1991 monty max 4x4. V6 to 4g swap & RHD. need 4g fit aide
    Connectisuck, New England
    1991 Mitsubishi L200
    brake & clutch 85% done....
    so i pulled the BS clearance lights that some dumb shite drilled 3 holes x5 lights so x15
    holes in the paper thin roofskin. lots of body work up here:
    looks much much betterer.
    Got the brake booster plate cut out and the mitsu logo too:
    And the plate re-enforcements and clutch support all welded in place, then a quick grind
    and some primer until i can prep the whole cab and paint the floors, firewall, and jams.
    i still need to make two bosses to bolt the tabs on top of the brake pedal assembly to, but i haft to wait
    until I patch the old blower motor intake hole, because one of the tabs is under that hole at present...
    i gotta go to an appointment at 9am, so im done for the night/morning. ill be back at it later on.
    hopefully that steering box shows up in the next few days. im ready for it.
