Associates Degree
Does your truck have a weber or the stock carb on it? My truck had a weber on it when I got it. This eliminates the need for the vacuum control box on the drivers side inner fender. With the Weber I have 1 vacuum line, to the distributor. I removed the egr piece from the intake manifold and fashioned my own plate to cover the hole. It is on the bottom front side of the intake manifold held on with 2 bolts. I then removed the other portion of the egr from the exhaust manifold. I cut the metal tube leading up from the exhaust manifold, and removed the large nut that holds the tube in place. I then fitted a metal plug into that nut, and tightened it back into the hole. Someone may make a kit for it, but I just made my own out of some metal laying around the shop. I would expect to see some type of threaded plug and a flat plate with two holes for the complete delete. If you don't have a Weber, strongly consider getting one as one of your first purchases. It will bring the tech level under the hood back to early 70's and give you better power and driveability.
I don't have any pictures of the original egr setup, but if you follow the tube coming off of the exhaust manifold you should be able to follow it all the way to the intake.
I'll try to take some photos of what I currently have.
