Results 1 to 25 of 28
Thread: Faulty temperature sensor, or gauge?
Threaded View
  1. #14
    Seattle, WA
    Old thread (?) but my temp gauge not working (again) and truck (Mikuni carb) runs rather rich ~ am ordering the two blade CTS from Rock Auto (oreillys napa autozone no have correct sensor)
    The two-blade CTS is for the feed-back carburetor system and computer. Replacement might help the rich condition but not the gauge. The sending unit for the gauge has a single blade. Look at the schematic in the Haynes manual, page 12-13. The single wire to the gauge CTS is red on yellow. (Haynes may have printed the schematic for a Gen 2, but I bet it's the same for your Gen 1.)
    The test for a Gen2 gauge: disconnect the wire and ground the connector through a test light. Turn key to "On" and the light should flash and the gauge operate. If only the light flashes, the gauge is faulty. If no light or gauge operation, the sending unit or gauge circuit has a fault. I bet the same test applies to your truck. If you think it's the sending unit and you can't find one, I have extra used ones you're welcome to.
    Here's the gauge sending unit per my parts list, P/N MD001380:
    https://www.ebay.com/itm/293183077612
    Note that it has a squared off end. You don't want the single blade unit with a bullet shaped end. It's a switch, not a sending unit.
