Senior
Chunks of the rubber boot are still stuck to the slider pin... lol
Thankfully the passenger side was less stuck and didn't require vise grips to remove. The pistons do move inside the calipers, so they will work once I get everything back together.
The only things left are to clean and re-pack the wheel bearings, put everything back together and get back to driving it.
