Junkyard diving was successful. I got the gauge cluster hood, center dash panel, cargo light, passenger side door sill trim, rear view mirror, and the clips for the sun visors. I did find a few other things there that I will be going back for, like a full drop-in bedliner and a set of diamond plate running boards. Might look for a grill guard too, if I can find one.
I got everything installed, replaced the blown radio fuse again (I have a feeling the second fuse was blown before I installed it), installed the block off plate for the fuel pump, got the electric fuel pump relay mostly wired up, and fixed two coolant leaks. One was the lower heater hose in the engine bay, the second was the hose on top of the heater valve.
Only two things left to do: figure out which wire to tap into for the fuel pump relay and where to tap into it, and finally tackle the passenger side front shock. Tomorrow I will be starting the truck, and posting a video of the first start.
It's getting really close, and I'm excited.
