Originally Posted by
WarStryker13
I got the new pins, but the boots that I ordered weren't the boots shown in the picture... So after a trip over to the local parts store, I've got another set of boots on the way and a new 75 group battery with dual terminals.
I did grab one of the cheap battery hold-downs, but I'm not a big fan of it. I thought it was made of some type of hard composite plastic, but it is in fact made of rubber and I think I might be switching it out for a sturdier battery hold-down. It holds the battery in place just fine, but I'm not really that comfortable with it as a long term solution.
I am picking up the (hopefully correct) caliper slide pin boots tomorrow, the 2 1/2" hub lock nut socket, (the Ford/GM one and grinding off the 4 extra pins), and while I'm there I'll grab some universal power distribution blocks and more electrical wiring connectors and ends to (hopefully) get the wiring mess figured out and semi-sanitized. Probably some other stuff that I won't remember I need to buy until I see it on the shelf.
I'm wanting to isolate the ignition wiring from the rest of the electrical wiring, and I'm wondering if there is another keyed +12v source I can use that is easily accessible and will potentially handle the possibility of up to 10 amps...
I'm going to do one power distribution block for battery +12v and the other for keyed ignition +12v. The battery +12v will power the fuel pump relay, the off-road lights relay, the 12v triple socket box I've got mounted under the dash and the tiny 100w sub behind the seat. The keyed +12v distribution block will run the electric choke on the carb, the signal wires for the two relays and possibly some additional accessories and/or relay signals.
The power distribution blocks I'm getting have a fuse for each output, and I will be running a 30a fuse maximum on the battery +12v block, and the keyed +12v will only have signal wires connected, nothing that will actually put any real amperage draw on the keyed +12v source.
I've got a buddy that has a seal installation kit, big ass torque wrenches, and a couple other tools that I'm likely to borrow. This upcoming weekend I've got 3 days off and I'm going to do my damnedest to have the truck back on the road by Monday.
