Sophomore
If by the warm air tube you mean the one from the exhaust manifold cover to the hole in the bottom of the air filter cover intake, that would be a negative as my exhaust manifold heat shield is missing and the manifold itself has several cracks in it. Finding a replacement seems nearly impossible so far.
I didn't even know the carb had water lines going to it, will have to investigate that.
