just acquired a '93 max; standard height and found some tundra rims 16x7 w/a center hole big enough. can I safely put some 225/60's on all 4 corners? looked thru the forum and could find no definitive answer. any and all input appreciated.
If they clear the hubs and the offset is good, they will work with no issues.
the rims clear the hubs just fine, and it looks like the offset is about 4.5" from the inside edge of the rim and about 4" from where the tire bead seats. and thank you sir for the response.
I have 31 inch tires on my mighty. I had to put wheel spacers on for the rubbing. It rides like a boat
What wheel spacers are you using? Do you have a part number and site you bought em off of. Really want wheel spacers but I dont wanna ruin my truck and get shitty ones
