Results 1 to 4 of 4
Thread: 91 6g72 wont idle once warmed up
    Jonesboro, AR
    1991 Mitsubishi Mighty Max
    Im thinking it IACV. Anyone else run into this issue? Before I start throwing parts at it, I'd be curious if anyone else seen this before.
    Any weird intake noises? Removing and cleaning out the IAC will cost you time and a few bucks. Worth a try. Maybe clean out the throttle butterfly as well...
    Jonesboro, AR
    I'll spray it down with some starting fluid and see if there is a vacuum leak. Its a back burner project. Ive owned the truck for years. Working on making it turn key reliable again.
