Results 1 to 6 of 6
Thread: Truck died
    Denver CO
    1986 Dodge D-50
    Truck died
    Hi all
    I went to the gas station and my Truck totally died. It started up fine for not having been started for about a month.
    When I went to restart everything you died with the first turn of the key. I cannot even get the radio or fan to come on.
    I figured it was a dead battery but still nothing functions even with the jumpers and a now charged battery.
    All of the fuses under the dash are good.
    Does any one know where I should even start to look for my power loss?
    First place to check is the ground cable from the battery. They get corroded and then there's no continuity.
    p.s. -
    Just for the record, I'm a carpenter
    Denver CO
    1986 Dodge D-50
    Ground cable is clean at both spots
    There is a fusible link that is off of the positive terminal that goes into the harness - it looks like a piece of wire with connectors on it. If that fails, the truck goes dead. you can jump it out with a piece of wire until you can get a new one or replace it with a fuse holder with the correct fuse.
    Denver CO
    1986 Dodge D-50
    you were close.
    The lead coming off of the battery splits to two wire (I think)
    the white wire's connector was crummy, looked a little burnt or tarnished.
    Cleaning it got the truck running again.
    Saved by pennyman1
