Rear differential
Start off by saying it’s been along time since I’ve been on the fourm I’ve been doing quite a bit of work to the old Dodge in respects to the Dodge I’m wondering if anybody has any information on how to turn the rear differential into a Posi track unit or if any kind of parts that are available anybody that would like to chime in it would be greatly appreciated thank you Howard
Doctorates Degree
These trucks came with a factory LSD option in 2 different final drive ratios. The Montero is also an option for a rear end swap. Nut and bolt swap I believe. A few members have done the swap themselves and I'm seriously considering it myself.
Powerbrute sells a lsd - same as the factory one. It is LOM83, and there are several new on eBay right now.
