Results 1 to 12 of 12
Thread: Timing belt change
    Vacaville CA
    Timing belt change
    Does anyone have a link to a timing belt swap or any pictures??? kinda in the middle of this and can't find what i am looking for on here
    http://www.mightyram50.net/vbulletin...G64-5-spd-D-50
    Scroll down the menu and click on what you need. Should be HERE. I took lots of pictures, and camoit just posted perhaps the most important one.
    Hope it helps...let me know.
    Vacaville CA
    Looks like the compression on 2 and 3 cylinder won't hold at all. Don't think I'll rebuild it so I'll just drive it till it blows up.
    Not going to try and replace the head gasket?
    Here is a link to one of our downloadable car manuals that should answer all your questions. There are also many other manuals available for our trucks here and all free. The manual has a great step by step information with illustrations. I usually use a couple manuals if one doesn't show it completely, the other one will.
    Haynes Automotive Manual 1983-1993 Mitsubishi / Dodge /Plymouth
    http://www.mightyram50.net/d-50/Fact...-1983-1993.zip
    Vacaville CA
    I don't think so....I might try to just drop a new engine in and rebuild the old one, just for shits and giggles. I need a daily driver and my buddy said we can sway the motor in an afternoon.
    Alexander City, AL
    The"fire ring" metal cylinder "seals" will rust out and the HGaket will then loose compression & "blow" when antifreeze isn't maintained. I am replacing mine now. GL! (IT (engine) won't "BLOW" from this unless oil gets contaminated (or not changed while waiting to "blow")... Remove &check head, regasket and replace. Enjoy! There is a truck fsale with 398,000 miles on CL!
    Vacaville CA
    I figured it won't blow...I am looking at getting a dodge neon with low miles for my wife. When we get our hands on that ill rip into more. Right now I odnt have the time or the replacement car to do something like that...or the knowledge.
    Alexander City, AL
    Understood. My situation also (re no other transport). I have to do mine next Monday as the machinist is only at parts house Tuesday -Thursday! (In case parts are needed to be ordered. "Blue Devil" did partially seal my HGasket temporarily!! and it was blowing back!! even!
    fortworth
    1991 Mitsubishi Mighty Max
    so the tentioner for timing belt a wont budge and its a bit frustrating so i need some help with how to get it off.
    Lincoln, AR
    1984 Dodge Power Ram 50
    4D55-T
    Quote Originally Posted by mighty boi View Post
    As in the bolt or you can't get the tensioner to play? It is meant to pried with a bar or screwdriver. There is a molded lip in the engine block to pry off of.
