does it feel like she is running out of gas? Change the fuel filter if you havent already.
Junior
No I havent yet but sounds like I need too. Its on the side of the tank right? Its weird cuz after I hit a speed bump pretty hard it acted up and I do hear the fuel pump trying to work harder and the motor shakes and just starts up low and eventually comes up to speed but it does start right up thank god lol
I believe your truck is fuel injected. Check to see if anything was knocked loose on your intake piping. A loose hose can cause your maf or mas to not read engine load.
Junior
Yes it is a 94 fuel injected motor and the speed bump might have loosened something but I will replace the fuel filter and check all my connections when daylight comes lol.
So that's a no for the night tweeking with a flashlight then? Lol. Let us know what you find.
Junior
No not this time lol but I will keep everybody posted on the progress.:p
So you now have a rod knock? Sorry to hear that.
Junior
Yea unfortunaly but I done got the motor pulled out. I am preping the spare motor today and get it ready to be dropped in. So I can start driving asap I dont like borrowing my dads car lol :p
I know how that goes. I haven't had a car in weeks. I kept having to borrow my sisters car and girlfriends car. That comes with picking up and dropping em off.......
Junior
Junior
Got my truck running again yay i had to put in a 88 2.0L with carb yuck but i got my truck back tho I will post pics soon.
Dude........ That sucks.. Now what are you going to do?
You got me a little confused. I thought the 2.4 was a wide block and the 2.0 was a narrow block. Unless the 2.0 is an automatic. Or you swapped the trans too. I'm so confused.....
Junior
naw the 2.4L and 2.0L is the same block just different heads cuz both have a 6 bolt flywheel and both are 5 speed trans motors and i kept the trans in the truck and just swapped flywheels from one motor to the next and put it in. I have a 88 2.0L and the 2.4L was a 94.
Inactive
HEY! there is nothing wrong with rocking the 2.0! espescially since the 2.0L was still sitting there like a faithful puppy, just waiting for you to use her once more!, and she, of course, is running still where the 2.4L is not!.... lol
If your gonna go through the trouble of engine swappin might as well bump it up to the 2.6L.
I think he's more concerned about having a carb instead if the fuel injection.
I'm happy with my 2.0 too.
dohc turbo.
Bachelors Degree
I swapped a 2.4 for a 2.0 and had to swap the trans cuz of the wide/narrow block deal. 2.0 carb motor was out of an 86 I think and went into my 1990 max.
That's why I was confused. I think he had an auto 2.0 cause thoughs are wideblocks if I'm not mistaken.
