Results 1 to 3 of 3
Thread: Filler neck tube
    Pomeroy, WA
    1989 Dodge Power Ram 50
    Filler neck tube
    Hello all,
    My '89 D-50 has a fuel filler neck hose that has cracked and failed. I'm told OEM parts aren't available. Anyone have any suggestions?
    Not sure if both ends are the same size. Will have to lower tank to decipher.
    The filler hose is the same diameter from end to end. Might have to pull the filler hose out and go trawling the JY's for something similar. The joys of owning an older vehicle...There will be plenty of full size trucks that will be newer and might have a solution for you. Never know, you could find a bigger capacity tank that could work as an upgrade.
    I went to an industrial hose supply house and got some tanker fuel delivery hose - I believe it was 1 1/2 inch. Take the neck or old hose for them to compare.
