The coil will if the ignition is on and you actually get the engine running. And you won't forget the first time you get buzzed by an ignition coil - funny to watch some other poor fool take one for the team but stings like a biatch when you've on the receiving end. Especially with the transformer type coils. Fun times... also if the resistor is hot and you try hitting it with a spot of water, the sudden change in temp could cause it to crack (if it wasn't already) Basically, you will know if the resistor is baked by touching it long before you singe yourself unless your reflexes are glacial-like.
