Results 1 to 4 of 4
Thread: fuel injector help
    Fresno, CA
    Unhappy fuel injector help
    I have a 1994 might max 2.4 my injectors got messed up and only one was working so i got new ones now my truck wont stay on. i redid my harness to them and i am going to buy a new ecm. Anyone had any problems like this before?
    Hi and welcome to mightyram. What are all the symptoms the truck is showing? See if you can pull error codes from the ECU to get a better idea of what is going on. There's an underlying fault that took out the injectors - could be a contaminated fuel problem, bad fuel filters, the fuel pump is dead etc.
    Fresno, CA
    The truck wont stay on its just crank itll saty on only when i spray gas into the throttle and then it will sputter and die out.
    injectors are not firing - could be the ecm. That is a classic sign of a bad ECM - did you pull the cover and look for leaking capacitors? Your injectors you started with may be good.
