Results 1 to 7 of 7
Thread: Cylinder head questions for my 92 mighty max
    Wasco ca
    I was in need of a replacement head for my 92 mitsubishi mighty max 2.4l nd i came across a 89 galant head that looks identical to the one i need to replace the only difference is that it has roller rocker arms..my question is will this head work on my truck or would i have to change the cam shaft nd rocker arms
    The roller head is a 16V head? None of the SOHC 8V components are cross compatible...
    Wasco ca
    No its a 8 valve
    miami, fl
    1991 Dodge D-50
    got a old free 1990 sonata 2.4 sohc motor and the head seems the same as my 2.4 D50
    If the Galant head is that 'identical', u should b able to swap over everything
    take pictures of it
    Hyundai used the 4G64 motor (2.4) from Mitsubishi, the blocks were labeled 4GCS, should be the same.
    Wasco ca
    I cant figure out how to upload a pic from my phone..
    Wasco ca
