Hate to seem like a total New User... but where are the ballast resistor and the fuel Solenoid (which I think I have found, front left side on the carb,,, at least that where one group of wires seems to lead...
My guess to replace that guy I need to take the carb off... is that correct?
One other thing... when I unplugged that wire harness that sits on the fender with the wires that leads to the carb... the truck ran past the warm of phase... I hit the throttle and it came down (rough idle but it idle and did not cut off until I turned it off...
Then I hooked the wire harness back up and started it the motor and it would not stay running...
I want to do everything possible before spending any money on a weber as they are pretty expensive... thanks again all
