Thank you so very much for this...I will give these things a try... so sorry or the late reply!
Quote Originally Posted by Soular View Post
I have the same truck and its doing the same things... but it starts up again...just will not stay running... worked fine all weekend then monday as I drive it it was hard to start but I just thought it was cold then it started and ran until it warmed up and died... I drove it and I had to keep the revs up or it would die at a traffic control light or stop sign.
Even while on throttle you can hear it miss just a little... not much...but just a little rumble...but as soon as I come off throttle the Engine shuts down. I'm lost... I have a stock Carb and EGR I am sure they both need to be cleaned... looking for the proper technique so not to mess anything up.
I am going to change the plugs and wires... I have a new top part of the distributor ...I guess its the cap.... I will read up on how to install that...
If you have distributor... do you have a coil?
I was reading and Its hard to tell since their are some many version of the truck...
Thanks for the help!
May I ask ... did you every find out your issue? May thanks!
