Results 1 to 11 of 11
Thread: Front suspension
    Somerville Alabama
    Front suspension
    So I found some lift blocks for the rear that range from 1 inch to 5.5 inches. 5.5 inches to me is a bit much but maybe 1.5 to 2 inches would work. My question is what can I do to front suspension to match the rear I drive a 94 mighty max 4 wheel drive 3.0 liter v6. I found some coil spacers as well but don't really know if that is in front or rear and if that would give me any lift at all. Thanks
    Somerville Alabama
    Also I found energy suspension but I'm not sure what those parts would do
    These trucks are torsion bar fronts for 4wd - go here for new torsion bars to let you raise it up: http://adventuredrivendesign.com/oca...berian+Bushing
    To be on the safe side I'd use a combo of frame/chassis spacers + suspension mods so it doesn't screw with the geometry as much.
    they also sell body lifts for both 1st and 2nd gen trucks...
    Somerville Alabama
    Where can you find the body lifts? What's the brand ?
    Oakland, CA
    Somerville Alabama
    Will I be able to clear 33 inch tires with just the body lift?
    Hey check the John baker catalogue in the manuals section he lists all possible tyre sizes with standard, lifted, and flared trucks
    Somerville Alabama
    Where can you find torsion keys for our trucks
    there are no keys for these trucks, just adjust the screws on the bars - you need new torsion bars to get more lift, and swap the ucas for a 2nd gen Montero (not sport) to maintain camber.
