Results 1 to 15 of 15
Thread: Can not find a radiator for my 1993 6V 4x4 MM in my area...
    San Juan, PR
    1993 Mitsubishi Mighty Max
    Can not find a radiator for my 1993 6V 4x4 MM in my area. Any ideas which Montero radiator might fit or any other? Any changes to mounts etc if any? Thanks
    (sorry if I posted twice... i cant find my last post)
    Found this dealer https://www.mitsubishipartscentral.c...MtMGwtdjYtZ2Fz
    And this site with two at quite a bit less https://www.completeradiators.com/pa...teZZRadiators/
    At these prices it might be worth it to go in to a rad shop.
    Hi and welcome to mightyram. Is it worth considering using an all alloy radiator from ebay? They are generally cheaper and more efficient than the original radiators. You have the old radiator to use as a guide.
    Nevada
    My radiator for my 91 Ram 4x4 V6 was bad as well when I picked it up. Tried a couple online sites but none of them actually had the radiator I needed. Ended up finding an almost new one in a 250k mile might max V6. Good luck!
    miami, fl
    1991 Dodge D-50
    as mentioned, using your oem radiator dimensions, in/outlets size & position... u could find a plastic/aluminum substitute
    Usually a 'little tweaking' to get it to fit/installed.
    I do that with all my swaps.... normally maximizing the size (also must clear AC & intecooler plumbing)
    Not paid over $95 for one yet. Worked fine
    saw a turbo max on starquestclub with a perfect fit plastic/alum radiator from some other oem application
    I asked the source, but didn't remember the thread, to follow up on the reply. So we know they exist
    dunno about copper radiators lesser efficiecy or performance.... but they are considerably heavier & more costly
    San Juan, PR
    Thanks for the replies/help! Will have a look on ebay...
    miami, fl
    1991 Dodge D-50
    aluminium radiator alternative for us.... maybe?
    http://www.ebay.com/itm/400943614169
    miami, fl
    1991 Dodge D-50
    I've had grief with 2 of those types of radiators bought from ebay. Wifeys Hung dog Elantra (let me count the ways I loath thee - cores were 1/4" too short compared to original, 3 out of 4 mounting holes didn't line up, overflow port was blocked, 7 of the locking teeth weren't clamped over the tanks...and the bottom tank leaked and all from an ad that claimed "100% direct fit replacement for OEM and pressure tested" Add to that I paid freight to Oz on this POS and it wasn't worth me trying to return it to the supplier) Second one was on my eediot bros V6 Pajero. Guess what? SAME BS. I'd be prepared to buy a generic universal fit type all alloy radiator and mod it to work. Not much chance of it leaking and you start off with a 3 core unit + the prices are pretty good.
    miami, fl
    1991 Dodge D-50
    hit or miss... like everything ebay I guess. I've been lucky so far.
    Even down to radiators my current two airconditioned daily drivers
    Truck pictured has seen a diesel swap, then a twin turbo upgrade..... with that radiator
    found some others too
    San Juan, PR
    I ended up installing an aftermarket Montero radiator from the same years. Took it to the mechanic and he had to modify the mounts to install and change the lower hose to a Montero radiator hose. So far working great... well see.
    miami, fl
    1991 Dodge D-50
    glad u got it sorted out. Hose barb positioning on the V6 radiator very different than the 4cyl version
    here is V6: https://i.ebayimg.com/images/g/5B0AA...Ho/s-l1600.jpg
    I measured the space available and will try the later 97ish 4cy montero radiator for my mitsu 4cyl truck. $50 new
    In/Outlet seem like they're in the right position, radiator is a few inches wider x 1 inch thick core. Some tweaking req'd to mount
    San Juan, PR
    Now the car does not heat at all. I'm worried about efficiency. The temperature gauge never passes the second line to the right of the "C" mark... i guess bigger radiator is not always better.
    Your thermostat will be the culprit
