Results 1 to 4 of 4
Thread: How to install AC compressor?
    Atlanta,GA
    1993 Mitsubishi Mighty Max
    Hi all,
    I have a 93 mighty max 2WD. 6 years ago I tried to charge my AC but found that as I was charging the refrigerant leaking out from the compressor. I determined the compressor was shot. I therefore deleted the compressor from the truck.
    Now, I am thinking of restoring my AC system so that I can use this vehicle for work.
    My plan is to buy a reman AC compressor online. Install it and hook up the belt. Then buy refrigerant from Autozone (They sell them in a can with pressure gauge). Charge refrigerant, then done~!
    Will my above plan work? What else should I be watching out for? I have never done any AC work. Any comments or suggestions are highly appreciated!
    Also, where to find the O-rings for the fittings that are going to bolt onto compressors?
    Yuta
    pa
    I'm pretty certain you will need to covert it over. R134a. And a new filter dryer and txv.
    pa
    The needed O rings should come with the compressor and filter dryer.
    there are o ring kits at any auto parts store - the green ones are for 134A. For best results, replace all of them so they are 134a compatible.
