sounds like a fuel relay or ignition switch issue. The start position is powered off the starter solenoid circuit, which bypasses the run circuit. Did you recently replace the starter? If you did, the old one has 3 wires, and the new one has 2 - there is your issue - see the thread on the s and r terminal starter thread.
