Results 1 to 8 of 8
Thread: gas filler neck ????
    pa
    Going to be changing my gas filler neck in the next week or so . My old one IS rotted out . Is there an easier way without having to drop the tank to get to it ??
    thanlks
    maxdsm
    https://www.fillernecksupply.com/d50...SABEgKyW_D_BwE
    If it's anything like the Gen 1 - no. It will make your like easier with getting to the clamps anyway. And you can give the tank a big clean and inspection while it's out.
    either that or pull the bed - neither is a simple choice. Is it the metal neck or the rubber hose?
    pa
    rubber hose and thanks .
    az
    Shouldn't have to drop the tank. I just replaced the hose going from the tank to the filler neck. The clamp on the top of the tank was a bit difficult but not impossible to get loose. As for the filler neck itself there should be a panel on the inside of the bed you can pull out to help make removing the filler neck easier.
    pa
    Excellent advice thank-you . Attempting this weekend .
    pa
    Replaced this weekend was a breeze . Dropped the tank (4 bolts) and removed tire and panel which made it very simple. Thanks Again everyone for the fast replies.
    pa
    Also found I needed to change the return line gas filter .
