I got a bonafide Weber from Triangle Auto supply, who Redline recommended. I let them talk me into the K610-38 GE, I hope I don't regret it. Anyways, so far my main question is...
Where do these huge threaded plugs go?? 2 of them about the size of my thumb??
The kit includes them but none of the "destructions" tell me what to do with them.
Also, I think I'm going to go with an electric fuel pump so that my fuel pressure is lower. When you go away from the mechanical fuel pump do you guys remove it and make a cover plate over the hole?
I'm rejetting the carb on the bench to hopefully get close to what my higher altitude will require...
I've got the original Mikuni carb removed so far, trying to go slow and careful...Any help/advice greatly appreciated.
Bill in Colorado at 8000 ft elevation
