Results 1 to 7 of 7
Thread: need G54B timing curves
    Portland, OR
    1989 Dodge Power Ram 50
    does anyone know what the cranking advance is on the 2.6?? and does anyone know where to find some 2.6 ignition maps for megajolt??
    Portland, OR
    here is a better question; at what RPM do i get max torque with a stock camshaft?
    after looking really hard i have found no ignition maps for a non-turbo 2.6 for megajolt. you can find them all day long for turbo applications but not for non-turbo.
    I thought we were talking about the same thing in here? http://www.mightyram50.net/vbulletin...=6225#post6225
    Find me on FaceBook
    http://mobilemillwright.com
    Portland, OR
    true. i should re post the question over in the other thread.
    In the other post in fig 3 around S6 is max HP @4000 RPM after that it falls off and then comes back up. So I would set yours up for 4200 rpm 25 deg of advance. If I'm looking at things right.
    Find me on FaceBook
    Portland, OR
    mine is a 2.6 though. the map in the figure is for a 2.0. are they that similar? i know they can interchange heads but aren't the cams different? and the other thing is, i am still a little unsure on how to read the timing map. i've been reading about ignition advance and load and how they corrispond to each other. i haven't had the chance to really drive my truck yet. i've been waiting on a new VR sensor bracket from the machine shop and then it goes into the shop for exhaust. after that i can really drive it and figure out the timing better and actually see what is going on when i press the gas pedal down. i will be able to better adjust the carb too after it gets exhaust.
    If you have the stock distributor take it to a shop that has an old sun distributer machine. You can map it that way. I would guess it's a Farly flat ramp. Ask LSRMike. He is the mitsu go fast man.
    If things work out we should have a new VIP joining the board. His truck has 36,000 Hp @ 376 Mph
    Find me on FaceBook
