Senior
I starts great runs great but it likes to diesel when I shut it off. Gonna double check the timing.
Senior
Seafoam didn't help so far.
what plugs are you running? your heat range may be off, causing the dieseling. You can also get an anti- dieseling solenoid for some Weber's - you use the same wire that goes to the electric choke - ignition off, fuel shuts off. Joetlc on eBay carries them.
Associates Degree
Also if your idle speed screw is too far in exposing a transition port from the idle circuit it will diesel frequently. The solenoid will shut off fuel to that as well. Allstate Carb out of New York has the solenoids, and good prices on all the weber jets.
Senior
Pennyman plugs are an ngk. I'm not sure on part # but that's my next purchase.
Giovanni I got my rebuild kit from all state. I need to get into mine and see what jet it has. My idle air screw is close to three turns out. I've been slowly adjusting it to get it running good. If getting it tuned right doesn't solve it I'll get a solenoid.
Senior
Added a muffler today so it's one step closer to being completely street legal. And it's up to 50 miles with no problems so far and with being said the gremlins should start popping anytime now.
