Thanks
The stud in the center was hitting under acceleration. I trimmed it flush with the wingnut and it was fine. I have new motor mounts that I was planning on putting in when I rebuild the front end. Hopefully that doesn't lift the engine up to much. I've got another half inch or so downward before i'm on the valve cover. I may redo this with a snorkel box setup that also bolts to the valve cover for a little more support. Feed it from the cowl area and wrap it in a foil insulation.
Giovanni
